April 22, 2026, 05:02:46 am
| |-+  Gaming (All your Gaming needs are here!)
| | |-+  *DAMN Mod Section (Moderators: *DAMN Mauti, jn.loudnotes, Toby, Casper, BFG)
| | | |-+  help
Author Topic: help  (Read 12726 times)
Mahamud Razz
« on: April 21, 2001, 09:51:35 am »
I have a question. Is there a way to create skins for R6 or EW? Single or multiplayer? Any help in this categorry would be much appreciated.
Mahamud Razz
« Reply #1 on: April 23, 2001, 12:00:28 pm »
Please, anybody. I just need a link to a site that can tell me how or something. Oh, and i also heard about a site called modding central, but you need to register or something. Can anyone tell me how?Huh?? Please?
« Reply #2 on: April 23, 2001, 03:32:40 pm »
Hi Razz,
sure you can create skins for R6 and EW. The only thing you need is a write application, a photo application like Photoshop and the rsb converter of your R6 CD.(At least it is on the Mac cd). The easiest way is to convert  the textures of excisiting uniforms convert them to simple pics and open them in Photoshop. Edit the textures and reconvert it to a rsb file with the smae name before. Now start a game where you use the these uniforms and you can see your textures. For detailed instructions read our R6 Tutorial at our mod section! Good Luck.
Bernie (Guest)
« Reply #3 on: May 08, 2001, 04:55:32 pm »
Hi, I am Bernie.
About Traitors:
I know many fans would like to be to the other side. Yes, to be tangos and kill the R6 operatives. Is it possible? How?
Bye bye
Bernie
Bernie (Guest)
« Reply #4 on: May 08, 2001, 04:58:24 pm »
 I'm Bernie and yesterday I joined R6 Forum. I know Mauti and Ebola and
and I have 3 questions about R6.
1) M00_fm_killhouse2_mp.mps:
   In this tutorial you are alone and must fight against 30 tangos.
This mission doesn?t have the briefing plan and it doesn?t allow to choose the operatives and uniforms you want. I?d like to take operatives with me in this tutorial mission.
Can I do it? Which files have I to modify? How?
2) Multi Player & Single Player:
   The mission files  .MUL  and  .MULT  are for net play but I?d like to use them for single player.
3) All mission files have this:
// Gore info
1  or   0    // Gore disabled for this mission
   What is the GORE? Can you tell me the meaning of disabled and the meaning of 0 and 1?
   Can you answer my questions, please?
You can e-mail at:  b.liggi@tiscalinet.it
   Thank you,
   Bernie.
Greeting from Italy!
« Reply #5 on: May 08, 2001, 07:27:40 pm »
Gore is blood! And about the other questions RS offers a test.brf as well as a test.int so you have to link to these files. How you can do this read throught the modcreating guide. One hint: You have to open the mission.lst and then you have to remove the pln link because this is the reason why it immediatly starts the missions. Then fill in test.brf and test.int in the right lines and thats it. Ah you also have to link to a .mis file but I think you will get it.
Bernie (Guest)
« Reply #6 on: May 10, 2001, 04:43:10 pm »
Hi, Mauti,
I have tried to do what you said but R6 crash. There is something wrong. I think I did some error.
But what I only wanted was to know how I can take some operatives with me in 2 missions: m00_fm_citystreet_mp  and   m00_fm_citystreet_mp.
Later I tried to modify the  m00_fm_citystreet_mp.pln,
I have add three operatives in the plan.
I wrote this:
citystreet_mp.map
M00
m00_fm_citystreet_mp.mps
4    (It was 1. I set 4 because I put 4 operatives in the team)
"TeamMember0" "Chavez, Ding" 4 chavezf.bmp Chavez.act avatar 0 0 0
"TEAM MEMBER"
"Olive Green-M-16A2"
"none.bmp"
"dummy.txt"
"Primary"        "pw_m16.wpn"        50
"Secondary"        "sw_45.wpn"        1
"team_olivegreen"
3
"olivegreen_a"
"olivegreen_b"
"olivegreen_c"
3
"olivegreen.eq.eq"        1
"flashbng.eq"        50
"frag.eq"        50
"TeamMember1" "RESERVE2" 25 Reservef.bmp RsrvAslt.rsv ai 0 3 0     (I add this  copy-paste from another plan)
"TEAM MEMBER"
"none.bmp"
"dummy.txt"
"team_olivegreen"
3
"olivegreen_a"
"olivegreen_b"
"olivegreen_c"
3
"flashbng.eq"        50
"frag.eq"        50
"TeamMember2" "RESERVE3" 26 Reservef.bmp RsrvAslt.rsv avatar 0 0 0   (I add this  copy-paste from another plan)
"TEAM MEMBER"
"none.bmp"
"dummy.txt"
"team_olivegreen"
3
"olivegreen_a"
"olivegreen_b"
"olivegreen_c"
3
"flashbng.eq"        50
"frag.eq"        50
"TeamMember3" "RESERVE4" 27 Reservef.bmp RsrvAslt.rsv ai 0 1 0   (I add this  copy-paste from another plan)
"TEAM MEMBER"
"none.bmp"
"dummy.txt"
"team_olivegreen"
3
"olivegreen_a"
"olivegreen_b"
"olivegreen_c"
3
"flashbng.eq"        50
"frag.eq"        50
"m00_fm_citystreet_mp.mps"
4   (It was 1. I set 4 because I put 4 operatives)
0
leader member member member 32918.6 33317 30347.6
253
"Deliberate Engage"
MoveTo 32918.6 33317 30347.6 0
__________
Then I tried it but R6 crash. Why?
Tell me what do you think about it?
I have created new skins called Olive Green but don't worry because it is OK.
Bernie.
« Reply #7 on: May 10, 2001, 06:10:54 pm »
Lol why do you have modified a plan file??? However I will send or post the right file here tomorrow. BTW Lol you can't take coordinates from other maps Wink jesus. R6 must CRASH.
« Reply #8 on: May 12, 2001, 09:41:58 am »
I snet you the file plus instructions!
Bernie (Guest)
« Reply #9 on: May 12, 2001, 04:48:00 pm »
Thank you a lot, Mauti
Thank you again
Bernie (Guest)
« Reply #10 on: May 12, 2001, 04:50:03 pm »
Why did you say I didn't change the plan file?
Do you know how put and place the trees and bush in the map?
The coordinates are in cm.? Where the coordinates start from? From left to right, from up to down? Are they cartesiane's coordinates? I mean  X  Y  Z .
How can I draw them? Which is the way?
« Reply #11 on: May 12, 2001, 07:58:41 pm »
First you can't set any trees or bushes you can only put barrels, cars, planes and other avaible objects on the map. You can gather these coordinates with the help of the debugkeys. Read the modcreating guide, how to use the debugkeys.
However I never said that you didn't change the plan file I wrote why did you change a plan file!? This can only cause crashes hehe.
BERNIE.
« Reply #12 on: May 17, 2001, 03:56:42 pm »
The Missions:  _MUL.mis, _MUL.mps, _MULT.mps  are for multiplayer, but I ask if it is possible to play them in singleplayer mode.
I have tried to set 0 (This is an adversarial mission) but it doesn?t work!
What are the Spawn points? I don?t understand the meaning.
What have I to modify to play the MUL and MULT missions in singleplayer mode?
Anyone can help me, please?
_________________________
I want to add new missions in the tutorial list but I don?t know the way, can you explain to me, please?
1                        // Number of insertion zones
29539.8 32157 35452.9            // Insertion zone corners
29328 32157 34280.3            // Insertion zone corners
I suppose the first line is the up-left corner and the second line is for the down-right corner. Can you explain it to me?
This is a part of the plan file:
253
"Deliberate Engage"
MoveTo 32918.6 33317 30347.6 0   (Can I delete this line? It is the same?)
_____________________________
This is a tutorial mission with briefing.
// Briefing Data for Mission ??
0                        // position of name and time-stamp in localization file
2                        // number of mission-specific pictures
"dummy_brief_picture.bmp"      // mission-specific pictures
"dummy_brief_picture2.bmp"
"test.mis"                  // objective text
3                        // number of briefs         (What is this? What does it mean?) (I suppose 3 are briefing, roster and kit screen)
// mission orders         (What is this? What does it mean?)
""                         // name of briefer
""                        // picture of briefer
""                        // briefer's text
""                        // briefer's audio
// control advisor
"na_a01_0.bmp"                  // picture of briefer
// first advisor
"Clark, John"
"dummy_advisor.bmp"
This is a tutorial mission with no briefing.
// Briefing Data
26                        // position of name and time-stamp in localization file
3                        // number of mission-specific pictures
"m00_1.bmp"
"m00_2.bmp"
"m00_3.bmp"
"m00_rc_double_room_1.mis"      // objective text
0                        // number of briefs
The question is: How can I do to have the briefings in those tutorial missions that don?t have the briefing?
That's all!
I know it is long but,  as you know, R6 is a great game.
« Reply #13 on: May 17, 2001, 04:07:29 pm »
You only have to refer to the test.brf. So you have a standard briefing you can use for all missions!
Forget to modify the plan files. You don't need to modify any plan files. If you want to play a _MUL mission in single player you have to set "Is this an adversial mission" to 0 and you have to take the coordinates(use a pair of the team start points) for the start points. Just copy and paste. And then you have to delete all files under the adversial line. Now change the Victory ?Condition first to "VicCondNone.txt" to test the mission later you can refer to a VicCond where you have to kill all tangos. (Just use the one that is used in the ?City Street Large mission) At the end you have to add this mission as a tutorial mission in the mission.lst. There you have to change many variables.
The best thing you could do even if you only have a 56k connection is to download R6 Never Dies and open my files so you can see what you have to change.
BERNIE.
« Reply #14 on: May 19, 2001, 04:21:59 pm »
I have tried to download RSND but it is so large!!!
It needs 3 hours to download and I can't download.
I'd like to get RSND but I can't.
...So , if you can e-mail some files (example: texture, skins, 3D model) I am agree! You have got my address.
bye Mauti
See you later
« Reply #15 on: May 19, 2001, 05:03:26 pm »
Download Monica(2.2MB) from our stuff section with this handy utility you can stop and resume downloads so to download R6ND shouldnt be so difficult!
Page created in 0.152 seconds with 19 queries.
