April 21, 2026, 09:40:58 pm
| | |-+  Covert Ops as UO mod
Author Topic: Covert Ops as UO mod  (Read 6885 times)
dave-s
« on: May 01, 2002, 01:09:11 pm »
How do I get Coveet Ops to run as a mod in UO, I tried before but it still takes over UO without even selecting it. I have noticed both the CO data and Mod file.
Any ideas?
Raven2367
« Reply #1 on: May 01, 2002, 04:15:10 pm »
Now. The way I did it with BT: I went into the BT file and clicked the mods file. Then i copied the BT mod file.
Then I opened the UO Mod file and put the BT mod file into there. Then you just put it on like a normal mod.
I hope you manage it
good luck
i hope I was helpfull
Take it EZ!
dave-s
« Reply #2 on: May 02, 2002, 01:07:07 pm »
Think it buggered up when I didi it like that, Ill try again with a full installation to a dummy file. Its funny because BT only loaded into the mods folder  Huh
« Reply #3 on: May 03, 2002, 03:45:40 pm »
Both of 'em work the same way. Once installed, they are in the mods folder. Just run UO, select them as mods, and play. Yes they will replace the splash screens, but everything is still there. it just adds the maps, weps, etc like any ol' DTD mod, just not as good... Wink Grin
dave-s
« Reply #4 on: May 04, 2002, 03:38:14 am »
Coco: COE hasnt worked like that. I first installed it months ago and it took over UO. Then I uninstalled it and theninstalled to a dummy directory so I could take the mod version. It didnt work, so I did it again. This time I installed to the normal directory then renamed it, then moved the files from its mod folder. This time it doesnt show up in the in game mod directory but is running? I dont know what I did different with  BT?
This is all because I cant get the No CD thing to work and its still buggering up my original UO CD.
Look another essay again Smiley
Raven2367
« Reply #5 on: May 04, 2002, 02:37:44 pm »
I dont suppose you turned the ''disable default primary'' and ''disable default secondary'' of when you had it on as a mod. because the it takes over UO on my PC.
Good luck dave-s
Take it EZ!
Page created in 0.045 seconds with 18 queries.
