May 01, 2026, 11:49:14 am
| | |-+  AirPort & Hosting...
Pages: 1 [2]   Go Down
Author Topic: AirPort & Hosting...  (Read 17984 times)
xoclipse
ownage
« Reply #20 on: July 25, 2002, 01:10:01 am »
Whooo, ok, let me try this.
I personally have an ibook, and am on an airport card with a linksys router. My hosting is...warpy, so i dont host, but it does work.
My linksys router may not be the same as your airport base station, but the same principles are in use, there are 2 important components to hosting through a firewall.
First thing though, if you have DHCP server enabled for your router, the dmz and port forwarding may and probably wont work. So manually set an ip and router address. etc,.
1. DMZ Hosting, like other said, it puts that particular computer in front of the firewall. Just type in your ip where you enable dmz hosting.
2. Port forwarding, as most of you know(cough**ejo**), the port that we manually join ?a game that is hosted through gr is port 15000. This port is the one gr uses. If you host manually through rs its 2346, or whatever you set it to. Now, port forward port 15000 for the particular computer you want to host, and that should be it.
Now, your computer is in front of the firewall, and it will forward all requests for port 15000 to your ip, so it should work.
I hope this helps, pm me if you want more help
Later
*DAMN Snake
*DAMN [SF]
« Reply #21 on: July 25, 2002, 02:24:08 am »
o i remember now DMZ is for airport hosting...and what i gave instructons for was how to get infront of a firewall to receive info from a router. but no one can connect to you because you still have a firewall called an airport... Cool
I'd like to see things from your point of view but I can't seem to get my head that far up my ass.  *DAMN Snake
"...to the last, I grapple with thee; from Hell's heart, I stab at thee; for hate's sake, I spit my last breath at thee."           in memory of grifter....may he R.I.P.
?{RiP}? Vapor
« Reply #22 on: July 25, 2002, 12:42:53 pm »
My AirPort is hooked directly to my cable modem. How do I set up a DMZ?
"From this day to the ending of the World,
. . . we in it shall be remembered
. . . we band of brothers."
Henry V
William Shakespeare
?{RiP}? Vapor
« Reply #23 on: July 25, 2002, 04:01:44 pm »
Yeah, but where do I enable the DMZ?
Henry V
William Shakespeare
?{RiP}? Vapor
« Reply #24 on: July 25, 2002, 07:30:33 pm »
Ok, well after Xoclipse and I played around with it, we got it so I can host. However, we ran into another problem - only one person is able to join and get into the game. Anyone know what the hell is going on?
Henry V
William Shakespeare
*DAMN Alex
*DAMN
BUCK FUTTER!!!!
« Reply #25 on: July 25, 2002, 10:12:31 pm »
Vapor, I have the same *&@$ing problem. But I just got used to it. I think us cool Airport people have no hope. Roll Eyes
I've got to ask you, about the Penis Mightier. No No thats the pen is mightier Mr. Connery
*DAMN Snake
*DAMN [SF]
« Reply #26 on: July 26, 2002, 01:59:02 am »
ok i found this, http://www.cisco.com/warp/public/794/600pat.html this should explain the ports problem so you know which port is and what it does.
*DAMN Snake ? Roll Eyes
ok i think i got it try this vapor and anyone behind a DAMN FIREWALL!  Grin
NAT (Network Address Translation)
NAT is used to share one IP address among several computers. A device set up as a NAT
router uses a collection of ?private? IP addresses (in the range 10.0.1.2 to 10.0.1.254) to allow
several computers to access the Internet using one ?public? IP address. When a computer
using a private IP address requests information from the Internet, the NAT router keeps a
record of the computer making the request, and sends the information to the Internet using
its own IP address. When the response comes back from the Internet, the NAT router
forwards the packet to the appropriate computer.
IP subnet
An IP subnet is a local network as defined by IP network numbers. Connecting to a subnet
involves connecting to the appropriate hardware network and configuring IP for
that network.
you will need to turn the nat check box on somplace in the program that the airport uses...
Now configuring your computer for IP connections
To set up your computer for IP connections, you need to make sure your computer is
connected to the right network and make sure that IP is configured correctly.
Selecting a network
With an Ethernet network, you choose the network by connecting an Ethernet cable to the
Ethernet port on your computer.
With AirPort, you use the AirPort application or Control Strip module to choose an available
AirPort network.
Configuring IP
Configuring IP consists of two steps: selecting a networking interface and selecting a
configuration method.
You choose a networking interface from the ?Connect using? pop-up menu in the TCP/IP
control panel. Choose Ethernet if you are connecting to an Ethernet network. Choose
AirPort if you are connecting to an AirPort network.
You choose the configuration method from the Configure pop-up menu in the TCP/IP
control panel. The three most frequently used methods are PPP, DHCP, and Manually.-- PPP is used for dialup connections to the Internet.
---DHCP is used frequently on Ethernet networks and by DSL or cable modem providers.
--- Manual configurations are used on Ethernet networks and sometimes by DSL and cable
modem providers which doing the step i posted before should ge you infront of that damn firewall  Grin,Your ASP  should provide you with the appropriate configuration information. phew...that a load of typing there.
well if you don't understand anything let me know
*DAMN Snake   Roll Eyes
Ok more stuff...
when inside the base station application go to networking thats were the NAT is located, also you need to check the "share a range of IP addresses". it says you need to use DHCP but don't. now the beginning IP addy should be 10.0.1.x any number the computer is not useing for the network, and the ending IP addy should be the same so you are decating one IP so that people can join, now let me explain what was happning before. xoc was connecting with that IP address and the airport would allow it, but when another user tried to connect the airport,it was giving it another IP which did not connect to anything. thus, no one could connect to you game but 1. by doing this it will devote one IP addy to your comp so several people can join  Grin
phew...not i am done
?{RiP}? Vapor
« Reply #27 on: July 27, 2002, 07:23:34 pm »
Ok. All that shit didn't work. When I clicked "Share range or IP Addresses" and it said all this shit when I went to update the base station. This is really pissing me off. I put everything back to how it was and if you want to private message me on GR and walk me through it step-by-step to do it then do that. But for now, fuck it.
Henry V
William Shakespeare
*DAMN Snake
*DAMN [SF]
« Reply #28 on: July 27, 2002, 11:52:39 pm »
bah...ok i'll ask a networking guy at work on monday, o and those were my father instruction's so give or take a little hes not a networking ?major...but i will find out from a pro just wait till monday ?Grin
Pages: 1 [2]   Go Up
Page created in 0.2 seconds with 18 queries.
